Tezz
so when I got car, it always bottomed out on front on really rough roads or big cambers at speed, eventually the springs on front snapped, both issues are well documented on A class, with a 50/50 mix of no owners having any issues.
I replaced springs after they snapped on front with after market ones and unless pushed hard bottoming out was improved.
I looked into this and read all posts and the variation of springs just from MB is a mind filed, after market was even worst from 390mm to 410mm
sports chassis ? non sport, increased load , data car ect, even some w169 specs are same as w245, and seams 5 door like mine, after market assume is same as 3 door, its a big mess
so I was thinking, cars ****ed on clearance for MB, for my car, no idea why don't care.
so options. up
put on A200, set up, put on the sports pack, check specs on after market
in my internet I found 30mm spacers fro car to raise it all 30mm, but unsure how this would effect camber ect ect t £150 for car
Then found the most un-popular kit for any A class owner, sports spring and lowering kit with struts and shocks approx.. £250. they drop it 30 mm
so this got me thinking, could you fit the lower sports set up, stiffer ride ect, add spacers, keep ride hight, but the sporty progression of springs stop bottoming out ?
or just add the 30mm rise to stock.
Im almost convince the bottoming out is due to, my auto over spec car, what I don't know is if MB know this?
problem is to check, I need to replace everything with OEM, at massive cost, with possibility to find out it was like it from new
so options. up
