Swirl Flap Actuator fault W212 E200 CGI
kamwithirwa
East London
W212 E250 CGI
The CEL is on. Star diagnosis revealed the swirl flap actuator is faulty.
I replaced the actuator (motor) but the issue persists. Teach-in fails .
Code P2006. Anyone encountered such an issue?
And often faulty motor blows up fuse, all fuses checked?
It may be just a misaligned pin in the connector.
Try disconnecting and check for corrosion or
dislocated pins.
Hi Kam,
I’m about to tackle mine when I get home from working offshore. Did you manage to get the motor out without removing EGR and other bits n bibs? Take it you have OM651 engine.
Probably installed on wrong position it needs a certain position to function properly
