transmission drain
thamesc180k
New Zealand
04 c180K
hi all, im about to drain the trans in a few days and will check the level first ( dipstick and filter etc on its way) but would like to know when i drain the fluid from the bung in the pan what quantity of fluid will i be catching? Can someone tell me please?
Thanks Karl
Thanks Karl
About 3.5-4L from the sump , the rest of the other 3+L is in the Torque converter and the cooler .
Plenty on YouTube for the” 722.6 5g gearbox “
Change the gearbox electrical plug at the same time , they leak after time .
If you have no drain plug on the TC one of these might help getting moat all of the ATF out.
its does have a drain plug but this piece of equipment looks the part. Thanks
