Hi 2010 C Class S204 1.8 Petrol 271.820 Engine Done 105K miles. I am getting exhaust gas in the coolant (leaking head gasket). I had the timing chain done about 2.5 years ago after the chain came off and 2 valves where replaced. Upon stripping down engine yesterday I discovered that the Turbo has a water supply. I am wondering IF this is a cause of the exhaust gasses getting into the coolant. The head is still on at the moment, if this is the problem then I have no need to remove the head. Can someone please advise Thanks Martin
