Underside brake line protection
W1ghty
Sunny Essex
E320cdi and CLK200
After @MrGundam started a panic by posting pics of his failed underside brake lines because of debris build up I’ve been waiting for a decent day to have a look under there on the CLK .
I combined the underside panel removal with a quick squirt of Dinitrol into the CLK’s rear subframe holes , a two for one job as the car was on wheel ramps .
I removed the long near side panel and was pleasantly surprised by there not being a huge amount of dirt under there . A quick degrease and scrub of the panel cleaned it up nicely .
The brake lines looked in good order , but I removed their rubber holders , sprayed everything with APC , scrubbed and washed with a microfibre mitt before rinsing . After letting everything dry i sprayed them with ACF50.
Had a crack at the E class brake lines today . Two under panels to remove , things were reasonably dirt free , even more so than the CLK .
I didn’t bother with undoing the body clips because it was cold and windy , I just applied extra ACF50 to make up for my laziness .
There was a fiddly section of brake pipe at the front that went right up close to the edge metal by the sill, I reckon if dirt were to get into the undertray this is where it might be prone to rust ?
Wow, He even put the car on its roof to do the clean up............ :oops:
It was easier to roll it over onto the lawn so I could stay upright and work at waist level ;) . ( I didn’t know how to move the picture round:()
I'm looking at mine tomorrow , 4 years and 15k . Don't expect to find much , but I'll check anyways.
Gimme a chance to try out my middle of lidl trolley jack.
I've just done checking mine , pristine underneath , the only thing I did see which I've not seen for a while - spiders legs 😳.
It was easier to roll it over onto the lawn so I could stay upright and work at waist level....
Woh that's hard work... next time, just buy one of these:
Job done! :D
For those of you who feel queasy looking at the upside-down photo...:
Everyone happy now? :D
🙃🙃🙃🙃🙃 happy .
