URGENT!!! Need a help PLEASE
astamir
london
w208 silver clk55
Hi guys urgently need a help
W208 clk55 here a part missing from the engine what's that part called an what's that for ??
That looks like it has a missing secondary air pump. It works on cold start up and then switched off after approx 25 seconds or so. HTH
What does it do an how important is?
Something to do with the catalysts heating up and air fuel mixture. If you google for Smog Air Pump you will get alot of info from the US forums. Or if your prepared to hold on then I'm sure one of daily resident experts will be able to help with a more precise answer. HTH
Not fitted to UK cars.
I think you will find that they are fitted on UK cars. Mine has one.
My C55, same engine I presume, has the secondary air pump fitted there.
When a hose from it came loose I got a 'check engine' light so I doubt you could run without it unless you sorted out the signal the ECU is expecting.
Cheers,
Phil
The additional air stops the petrol poisoning the catalytic converters or encouraging overheating of them.
