m80
- Apr 26, 2015
- Location
- Derbyshire, High Peak
- Viano ex long, 651 2014. S211 646 2009 (till the Gov't drones blow 'em off the road)
Not wanting to hijack a previous thread,
P0101 MAF and P2463 DPF soot problems... | MBClub UK - Bringing together Mercedes Enthusiasts
I've started this one.
"Mine feels like limp but revs to max and kicks down so not. I believe there is no turbo boost
With mine bringing up the MAF code before starting the engine I'm able to see that, to my mind anyway, it's a sensor or ECU fault.
I have been using the iCarsoft V2 till it also went faulty yesterday. That has shown me that the map boost sensor didn't change state while driving so I've ordered one.
It can show DPF differential pressure, exhaust back pressure and soot content.
I replaced my MAF last week and no difference
I believe cheaper non oem MAFs are suspect and can be problematic themselves, I went for Bosch."
Answer by HITECH
"Revs up to full but power loss. Yes that will be your exhaust back pressure sensor for sure. How sure am I . Well the components that cause that specific fault are very limited and the most common one is the exhaust back pressure sensor. Top right of your engine beside the EGR. I already am advising somebody else on the forum for a limp mode of similar nature. You gone about it the right way, DPF sensor then ...... Replacing your exhaust back pressure sensor and cleaning out your EGR and all the routes/lines full of soot should cure it."
Answer by HITECH
