Vibration at 37mph
Davevito
West Moors
Mercedes Vito 2014
Hi Everyone. I have a 2014 Vito van that has nearly done 250,000 miles that I bought from new. I have not had any problems with it until now. A vibration starts at 37 mph & stops at around 47 mph. It is quite severe with the whole van shaking. I have spent over £600 with a garage so far with various mountings changed but no fix. The wheels have all been balanced & swapped around but it is not a wheel wobble through the steering wheel as the vibration comes up from the floor. Any ideas anyone ?
What parts of the drive train have you investigated / ruled out?
Thanks for replying MikeInWimbledon. The UJ joint was replaced on the prop shaft as it was found to be worn, the rear differential mounting was also replaced & the front gear mounting replaced, both were worn. This has had no effect to the vibration
Was the vibration there before the universal joint was replaced.?
Fwiw I was told that my propshaft had been replaced on my little Vito (older model, 2007) shortly before I brought it at a bit over 150k miles. I was advised that it was replaced as a complete unit with central support bearing and everything because they "couldn't be properly reconditioned unlike most propshafts"
It sounded rather unlikely to me, but when I checked my entire propshaft was very obviously brand new compared to the rest of the underside components.
I seem to recall that they did say that it had been replaced "due to causing vibrations", but that is hearsay because I had not experienced it myself (and it was said by a used car salesman, so the proverbial pinch of salt always applies imho).
Hth.
Edit/
Have you checked the gearbox oil level ? -Fairly easily done, has to be worth a few min's just in case..
Hth.
Edit/
Hi. The first thing the garage replaced was the UJ. I'll check the gear box oil. The next thing to do I'm told, is to balance the prop shaft. I don't understand why it should go out of balance if the joints are ok. Thanks for the reply
Perhaps the shafts could have been rotated by 180* in relation to each other, whilst disconnected when the replacement universal joint was fitted.?
If the central U joint needed replacing, would that not suggest that the central support bearing would have experienced wear too? -And what about the other three U joints on the propshaft, wouldn't they also have a comparable level of wear to the failed item?
