Vibration - Gearbox/exhaust?
J30BOS
ML270 CDi
When the rpm on my ML270 Auto is at certain point there is a vibration in the car.
I have recently had a new cat fitted - could a problem with the installation be contributing or is it something more sinister like the gearbox or clutch?:(
Any help would be appreciated.
Jason
Do you mean the whole car vibrates, or you can hear something vibrating? If the latter it could simply be a heat shield that's slightly loose (tinny rattle), or the exhaust system slightly out of alignment and knocking on something.
Your auto gearbox doesn't have a clutch, so it's definitely not that ;)
And welcome, by the way :)
Did this only become noticeable after the new cat?
Check mounts are not being compromised.
Bazzle
