Vibration
Funkyboy
E class
Hi All,
I’m getting vibrations through the floor of my E250 when braking from speed. Nothing through the steering wheel. Got a slight vibration through floor at motorway speeds but it’s much more pronounced when you brake?
Thinking it’s wheel balancing but wouldn’t that be more noticeable at cruising speeds rather than braking? Or warped discs.
Anyone had similar
I also have a problem when braking, more of a rumble than a vibration, although I get a vibration at 60 which goes at 65, which probably is wheel balance. The rumble feels as though something is loose, like a brake pad, or even the suspension bushing. It may just be a warped brake disk. I am looking forward to being able to kneel down and get the wheel off when this clown boot is finally off so I can have a good look.
