Viper alarm system w124
chris3004
London
Mercedes E200 W124
I have a Viper 480XV alarm system that i am fitting into my 1994 w124.
The immobiliser is working the alarm is on, but having trouble wiring it up to the pump system.
Anyone have any ideas or feedback on how i can get this working?
I have attached a photo from the installation guide for mercedes pump system.
grober said:
One would assume when disarmed WHITE/BLACK would be connected internally to BLUE/BLACK to allow the trigger signal to reach the pump? http://www.mbclub.co.uk/forums/interior/134768-w124-central-locking.html Do the install instructions refer to the W124 ? http://www.peachparts.com/shopforum/diesel-discussion/281889-security-update-central-locking-defeat-124-126-210-a.html
thanks for getting back to me, i have now resolved the issue.
Care to share? :)
Im a CLIFFORD/VIPER authorised installer and quite happy to help if anyone has any tech questions or problems
Paul
Care to share? :)
Under the Drivers seat i found the cable which triggers the drivers door (Blue). When this is cut i needed to attach the door side of the cable to WHITE/BLACK. The other side which is connected to the pump to BLUE/BLACK.
The VIOLET cable connects to the RED/WHITE cable which fuses the pump.
VIOLET/BLACK connects to ground.
Last but not least (the part that i was missing before raising this post) connect the BROWN/BLACK & GREEN/BLACK cable on the VIPER system together.
Hope This helps.
Now i need to connect the rest of the alarm this weekend. :bannana:
Paul
Paul, I may have plenty of questions for you, would appreciate it if you have the answers :)
1) Can i get this certificate without a professional installing it?
