vito 115 help 2004
dive007cassie
have been getting some vibrattion when turning left end right checked the prop looks ok any body had this problem
This year/model suffers from rapid bush wear on the front suspension.
If you get a clunk/knocking over uneven surfaces or under acceleration it's a point to start.....
shudder , seams to be the rear when turning and when acelarate up the gears dose not sound good fitted new prop severval months ago check seam ok i dont no if it the rearwheels bearing the van done about 105000 miles
