maddernj
I had a leaking water pump, I have now removed it but along the way a few of the bolts / star nuts were casualties.
I now can replace thew water pump (MBF 1022011001), but I cannot get the Electromagnetic fan clutch off the old one.
I had to cut one of the supporting arms to remove the original water pump as the bolt has stripped its head (I am hoping mole grips and heat will get this out of the block).
a couple of questions, will the electromagnetic fan clutch be okay with two of the supports bolted down ?
I have read that the supports are on the earlier fan clutches and the later ones are bolted into place. Is there an alternative water pump I could buy and get the later fan clutch ?
Where is the bast place to get replacement bolts, the star nut that adjusts the Alternator is a bit rough, and the star nuts that held one of the pulleys will need to be replaced.
