- Dec 29, 2013
- Location
- Kidderminster Worcestershire UK
- Mercedes W124 260E M103
Yes i did see your post - And i can see that you have been running before you could walk. Sill i need to know what plugs you have fitted ?. I recon thiose are wrong ones for a start Dont even know your engine type . is it 110 or 115 You say you have set valve clearances ,,that are set by oil presure .[how] .. you might have checked clearances only .
And check ECU along with EZL One place you said you had not replaced the rotor,then you had .
You need a good mechanic to sort out your puzzle.
