W123 230e In almost perfect condition but it has 1 problem...
TMFACE
EN1 3AJ
W123 230e
I have found a 230e in almost perfect condition with a low 77k miles and has only had 2 owners but it has 1 big problem. What will the extent of the damage be and is it worth it?
You have no idea how far the corrosion has gone so prepare to replace the whole panel and have it painted.
Had to edit and reupload pic...
I edited and uploaded pic didn't work first time
Have you any other images of the corroded panel?
You have no idea how far the corrosion has gone so prepare to replace the whole panel and have it paipainted
The car is up for 10k how far would you reckon i could get it down they seem to think its just "a little bit of bubble on the paint". Everything else on the car looks very good
No but I've got pics of the boot and the rest of the car if I can talk price down I think maybe it would be worth it to fix.
Always difficult to tell from pictures but you can guarantee the rust will be more than a little bubble. If that is all it is then why hasn't it been fixed?
Any car of this age needs a through inspection on a ramp by someone who knows them👍
Glass needs to come out and the rust cut away and repaired. It's an effort but if the floors and other box sections are good, you'll be happier spending the money making it perfect
You really need to get in the boot and look up at the underside of where that rust is. Usually it’s far far worse on the underside. It’s not irreparable, but glass out and quite a bit of work
Just what I was thinking.
And if you buy an old MB for any price, have a few £K in reserve.
RayH
The car is over 40 years old and will have seen lots of winter rain, snow and salt.
With any old car, the visible rust is likely to be the tip of the iceberg and £10k is a lot for a manual W123 (never the most desirable option) with a large rust blemish spoiling its looks.
If possible, putting it up on ramps would be a good idea.
This is a common area for a S1-S3 XJ6 / XJ12 to rust so you might want to talk to a couple of jaguar owners and get idea of the LOE. I'd check the parcel shelf to and boot floor around the fuel tank as the water had to go somewhere. You might also need a headliner. I can't remember if the W123 had plastic panels over the C pillars or if it was headliner material. Headliners and welders don't go well together.
Minimum it will be rear screen out grind away the rust....which will be worse than it looks and go both ways along the window chanel, lead fill and respray...glass back in. Does not look anywhere near bad enough to need a whole panel from those pics. Paint matching on a car that old is never easy...but if your body shop uses a decent spectrophotometer and has a man skilled as using it and mixing the paint accordingly, it should be acceptably close.
Speaking as a previous W123 owner who did a full restoration back in the day, W123s are now quite old nowadays and were notorious for rot on the underside and around the wheelarches.. Personally I would not commit 10k to this unless you also have the underside of the car checked on a set of ramps or find a specialist who knows this vehicle to check it over. These cars are now quite expensive to restore.
Regarding the bubbling around the window, this is a common issue on this model. Unfortunately as others say, until the screen is out, it's difficult to say how far the repair will go.
Also remeber that there is no such thing as cheap bodywork repairs nowadays, especially if you don't want the problem returning.
