Eiderdown
- Dec 26, 2024
- Location
- Colorado - USA
- 1981 Euro 230CE, 1997 SL320, 1972 Triumph TR6
I've recently purchased a rather battered 1981 230CE 5-speed manual in Euro spec from a fellow in Texas. The 230CE was not sold here in the US, and hence none of the repair manuals I've found cover the M102.980 motor. None of the US-based online parts suppliers, including my local MB dealer, are able to help with much either as that model/vin does not show up in any catalogues.
The previous owner had lost the only set of keys which constituted the first problem to be solved. After chasing several possibilities I ended up removing the drivers door handle and lock cylinder which I took to a local locksmith. He was able to make a key that fit all the locks on the car. Then came the moment of truth...PO said it "runs and drives" before he lost the keys. Cranked it over and it fired right up (yay!). Runs awful though...lots of things bodged up under the bonnet. So, I've verified the "runs" part but have not tried to drive it yet.
I know the 230CE was sold in the UK so thought I would reach out across the pond and see what level of support I could find. Several things I would like to know:
1. Repair Manual - what would you recommend? I do most all the work on my own cars
2. Vacuum Diagram - I would like to verify that all connections are correct and functional for the M102.980 motor
3. Online Parts Source - Suggestions for new/used parts vendors that will ship to US
Thanks!
Matt
Thanks!
Matt
