W124 E200 differential
chris3004
London
Mercedes E200 W124
In need of a differential for my e200. Not sure about ratios but I'm assuming there all the same for e200.
Please let me know asap
not all the same, Is the car sallon, estate or coupe? auto or manual? has it got ABS/ASD? there is loads of variations. ratio of your diff is stamped on the back on lower right corner, can check with diff in the car. just make sure you have WD40 on hand and something to wipe off the gunk.
Its petrol automatic with abs. I will have to get the garage to let me know whats written on the old one.
E200, M111 engine, auto should have a 3.27 diff ratio (Manual 3.67). The ratio should be stamped externally on the diff itself.
Thanks for your help John i will look around.
Still in need of diff
i may be able to help you, what is the ratio on the diff, and do you have ABS, i can't pm you as you do not have enough posts
