W124 Heating/Cooling Issues
ryanMIL
Nuneaton, Warwickshire
W124 E220 Saloon & Fiat Panda 100hp
Hi All,
The E220 W124 which I've recently been refurbishing has been pressed into service for the last couple of days to give me an opportunity to get to grips with some of the smaller issues. I'm pleased to say that almost everything seems to be working perfectly, however one issue is causing me a lot of confusion...
The blowers in the centre of the dash only blow out cool air, whilst the blowers on either side of the dash (by the doors) only blow out hot air, regardless of the setting on the controls. I'm completely confused!
On another note, the car runs at about 70 degrees according to the temperature gauge - is this correct, or should I be investigating?
Thanks in advance for any help on these,
Ryan
Centre vents are always cold on most W124s. Outer vents should vary - if they don't the Duovalve is the likely culprit
70 seems a tad low but if it's consistent I'd ignore it
Nick Froome
