W124 help
Howard
MB Club Veteran
Toad Hall
2018 C63 Wagon / CLK430 / A150 / VW Pink Floyd Golf Cabriolet
W124 help please
hi everyone ....
Quickie ..... will this fit a pre-facelift w124 coupe (J-reg) ? or will it require thousands of pounds worth of extras ;)
Are the pre and post facelift headlights the same ?
And it is miles away! ;)
C240Sport97 said:
but it's not white!
Ah !!! But it could be ................
Anyone got any ideas ? :rolleyes:
Howard,
I'll take your question seriously, even if nobody else does :)
According to Mercedes Enthusiast in Oct 2002, "The 1993 face-lift was a cheap upgrade for the factory, a fact reflected in the price of the parts when they were new and the popularity of retro-fitting the parts to pre-facelift cars. The changes were obviously designed to cause no disruption to the computer welding machines at Sindelfingen and, as such, all are 'bolt-on'. Even the slam panel under the bonnet is the same and you only need change the bonnet catch bolted to its underside. The headlamp reflectors are identical and, as the glass is a separate part anyway, only this was changed to incorporate a curved chamfer to clear the new bonnet. The slim, body-coloured insert between the headlamp and front bumper was also changed to incorporate a recess to clear the new grille. This is available in two forms, plain and with a hole for the optional head-lamp washers which were standard on UK-spec six-cylinder models."
So there you have it; the headlamps are nearly the same, but not close enough. You'll need new ones, or maybe just lenses if you can find them, and new filler panels for below the lamps. There's no mention of profile (inother words, 'will the bonnet fit against the wings without changing them?') so I would get it's not an issue.
Oh, you'll also need plenty of white paint. I'm sure you can get big 10-litre buckets from Wickes... ;)
And now for my catchphrase: Of course, if this all goes pear-shaped, then I was never here....
PJ
Cool, thats just what i wanted to hear ......
Now, where do i hire a van ? ;)
A Van??!!
You won't need that much white paint just for a bonnet! :D
PJ
The bonnet is miles away though
It will go no problem - even your existing lights will fit (just) but may look a little odd... only you (and us) will notice though :D
But then the facelift lights are cheap from ECP ayway.
How much you thinking of paying for it?
Howard, instead of painting the bonnet why not paint the car, it may work out cheaper ;)
BTW, dont bother with a van, you can borrow my roofrack for your Coupe. :)
LOL !!! just checked .....
I thought Pontefract was in Wales :confused: :rolleyes:
anyone in West Yorkshire want to collect a bonnet for me ? ;)
Oh Poo!!!!!
I forgot about this , the bloody bonnet sold for £2.20 !!! :crazy: can you beleive it !!!
