dylantaylor544
Hi Everyone
Heres another W124 mercedes with this very common issue it seems. The car is misfiring at certain RPM/Throttle body positions and sometimes it will stall at idle and then sometimes also battle to keep its idle. Throttle body position makes a difference, if you do a 20% easy pull off it seems ok, with an initial hesitation. Any fast pull of you can notice a heavy shudder. Once it reaches 4000rpm you can feel a noticeable improvement in power and steadiness.
The wiring loom has been removed and tested, it has been repaired before(previous owner) but it is all good. It has been to a merc specialist garage who tested the codes and the 02 sensor and MAF were replaced. After they were replaced the error codes cleared and retested and the same remained so it was suggested an ECU fault.
Currently the ECU is on its way for testing /repair but is there anything obvious that it could be?
