BillyW124
- Oct 22, 2010
- Location
- North West London
- W124 E320 coupe, W211 E320 V6 CDI, W211 E63 V8 AMG, R129 SL 280 V6, W215 CL 600 V12 Bi Turbo.
CKLclive
Very pleased with the results too!
The motor went through some extensive corrosion work and treatment this summer just gone.
We specifically concentrated on all the usual and common 124 corrosion woes and got it all delt with.
Summer 2011:
Here are a few pics:
Hi Chris, its a common problem on 124's and can be fixed cutting out the rust /welding new piece in preparing the surface and painting, done one a couple of months ago for Billy124 on his coupe
Summer 2011:
- All four Jacking Points treated. Corrosion on the sill around the points cut out and new metal welded in place.
- Rear fender arch lips treated after I had a lip roll
- Washer bottle grommet area in engine bay treated. Corrosion cut out and new metal welded in
- Front wings removed, treated in anti rust. Fender lips again treated after lip roll
- Inner wing skins treated in anti rust
- Rear inner quarter panels and drain grommets left/right corrosion cut out and new metal welded in
- Inner rear light cluster edges treated and sealed for water ingress prevention
- Areas of wheel well treated and a light blow over in body colour
- Driver side footwell corrosion (sill area) treated with new metal welded in and treated ( http://www.mbclub.co.uk/forums/bodywork/102710-w124-owners-anyone.html)
- Cavity wax injected into the sills
- Front lights, front bumper and rear bumpers removed to treat inner skins and mounting areas of the body
- Front bumper re-sprayed due to stone chips.
- Plastic claddings and sills re-sprayed in monotone effect to the rest of the body.
