W140 SRS light on after battery drain
1998S280
LEEDS
Mercedes S280
Morning all,
I only use my W140 once a month for a 300 mile round trip to my work office and when I moved at the weekend to give it a wash before this months journey the battery was completely flat. I tried a power pack and also tried jumping from a spare battery but neither worked so I put the battery on charge.
The battery was new in 2023 so I dont expect it to be the battery but did notice that when recharging it never reached "full". After 3 or 4 hours I gave it a go and it started OK but with the SRS light on.
I went to move the car yesterday to go for fuel as I intended to use the car tomorrow for the work journey but the battery was flat again, luckily I have a spare identical battery so I swapped them over and it started up but again the SRS light is and and doesnt go away even after 5 minutes of running.
I suspect a parasitic drain on the battery from somewhere causing the flat battery, any thoughts on this and the SRS light please?
thank you
no thoughts on the SRS light coming on and remaining on after a flat / disconnected battery?
can codes be removed with the cheap OBD diagnostics boxes and phone app?
For SRS codes you'll need STAR or professional equivalent. My local indy does it in exchange for a few beer tokens.
thanks Richard
should the OBD port be behind the flap in the drivers side footwell?20240616_124917.jpg
Wouldn’t this use the 38 pin HHT diagnosics port in the engine bay as might be too early for obd 16 pin ?? but I am no expert.
