DexterML
Hi all
The saga continues indeed. I am waiting for a new crankshaft sensor to arrive (changed the cam sensor), and my appointment to the indie for the diagnostics. In the meantime the car is just sitting there. I start it up every now and then to keep the battery from dying. And here is the thing. I started the car, let it run for about 15 minutes. Things happened in this order:
1. Turned off
2. The key wouldn't release from the ignition again....
3. Started the car again, the car wouldn't start. Cranked but no fire up.
4. After about 3 long tries.. it fired up.
5. Key still stuck. Turned the engine off again.
6. Turned engine on, wouldn't start.. cranked but no start.
7. Tried another 2 or 3 times, fired up.
8. Turned engine off, key got released from the ignition barrel.
Also, I noticed that there was a whirring noise coming from this.. I circled it in red below, which I don't know what it is... It usually died out before after a few seconds, now it seemed to go on and on for minutes. Anybody knows what it is?
Does anyone know what the car does if it doesn't recognize the key? In previous cars I had, the lights would turn on but the car would do anything. No crank, no nothing.
Would the engine still crank if the coder doesn't recognize the key in the ML's case ?
1. Turned off
