Felix66
Hi everyone!
Having a little(?) problem at the moment.
For around 2 days boot lid on my ML 320cdi(2006) wouldn't open. All the doors opened and closed fine, except boot lid.
Then, today, the rear o/s door's lock got stuck too. Again, other 3 doors were fine. I could only open it manually, once inside the car.
My first thought/plan of action was to somehow climb into the boot via rear seats, open it manually and then check the fuses.
Went to the car, unlocked it and, surprisingly, suddenly everything worked ok again, boot lid, rear doors etc.
Scratching my head in disbelief, I opened the fuse diagram to see if there is maybe a corresponding fuse..... Sure enough, not a mention of any of those except "Remote tailgate closing" which my car doesn't have.
Being a bit of a Frank Spencer with two left hands and fairly clueless about cars, I finally realised that maybe there is no such thing as fuses for boot lid and rear doors
My desperate guess is the battery(which one - there are at least 2??) must be on the way out and is playing up with electrics.
Not sure how to go about it ie. how do you check if your battery is empty(??) or perhaps insufficiently charged, maybe even dangerously old?
I tried looking through the owner's manual but not even a suggestion as to what battery is inside nor what the replacement one should be. Just the usual - visit your nearest MB workshop blah blah..
Shops(Halfords, ECP etc) mainly suggest a very specialist battery(AGM or something like that) which, as I understand it, is recommended for newer vehicles with stop/start function.
Those batteries are very expensive, and my car doesn't even have stop/start, so I thought it would be an overkill to get those. But if not one of those, then which one?
Please suggest any ideas as to what could be wrong with by boot/door locks playing up, as well as how to check the battery's "level"(if that is at all possible??), and where to get a new one if mine is not good enough.. Well, to get a new one, I should first know what make and model to look for, so if you have any idea, please help - I could do without a "visit to my nearest MB workshop.."
Any input will be greatly appreciated!!
Sorry for the long essay!
Cheers
Cheers
