I'm not saying it shouldn't be topped up, rather I'm saying that if the level has dropped there's a reason. It implies there's a leak in the system or it's being consumed due to a component failure somewhere. You're right to get your car checked and if it's pronounced to be "OK" then keep an eye on the coolant level going forward.
Antifreeze performance does deteriorate over time and it's also a corrosion inhibitor. Ideally it should be tested for concentration every few years and the coolant either changed or some drained and replaced with antifreeze so as to maintain the required protection.
