Had it about a month from a MB approved dealer with a 1 year MB warranty so I’m sure it’ll get sorted.How long have you had the car?
If recently purchased, was it from an MB dealer, a trader, or a private sale?
Modern cars are complex and things go wrong. You have a warranty, it will be fixed.Had it about a month from a MB approved dealer with a 1 year MB warranty so I’m sure it’ll get sorted.
Just not a great impression for my first MB.
Thank you, I do hope so.Modern cars are complex and things go wrong. You have a warranty, it will be fixed.
You purchased from a trader.Thank you, I do hope so.
Phew !Had it about a month from a MB approved dealer with a 1 year MB warranty so I’m sure it’ll get sorted.
Not a personal dig....but I think that anyone even doping a modicum, of research on these derv models just would not but one. It seems to be that is not if but when they fail. True other makers have similar issues.....but it does seem lots more common on Mercedes compared to other forums Im on. It might be warranty now.....but it wont be next time.....and will affect your sale price if you sell privately....I certainly would not buy any car with Adblue....or come to that any derv in these tree hugging days.....and I have one now!!Had it about a month from a MB approved dealer with a 1 year MB warranty so I’m sure it’ll get sorted.
Golden rule: If you get odd error messages on a car with CANBUS, try removing any and all aftermarket add-ons before assuming there's an underlying fault.The guy who fitted it had piggybacked a fuse that the car didn’t like and gave the adblue warning.
Thank you and noted.Thanks for coming back and updating the thread.
A very comprehensive and accurate replyI stand to be surprised but I bet that the owners manual will just say consult the dealer.
You have joined a very long list of people having adblue problems - google it. It is not just Mercedes.
There is nothing that you can do yourself to fix this problem; you will also be wasting your time with anywhere other than the main dealer or a proper MB independent with access to the Star diagnostics system.
The design of the adblue system incorporates an immobilisation feature that will prevent you from starting the car with an adblue fault left unfixed for a period of time. If you do nothing then you will get a message "car unable to start after 400 miles" or something similar. Don't think it is just to scare you - the car really will be disabled.
It is therefore better to get the fault diagnosed as soon as possible.
The fault is most likely to be either one or both of the NOx sensors or the sensor in the adblue tank. Wiring faults to the adblue tank have also been found in some cases. The only other possible cause is with a car that has had little use and the adblue has crystallised over time.
Cost wise the NOx sensors are about £400 each and the adblue tank sensor comes with the tank complete and is about £1200 all plus VAT and plus labour. So the bill will be between £1k and 2k ish. The bad news is that there is a shortage of parts so you may be without the car if it disables itself before you get it sorted.
No wonder people are turning to the adblue delete services that you will find on the web for a few hundred pounds - bear in mind that this would render the car illegal to use on the road.
