I wonder if there's a reset function to test different air con settings on 1999 W202 ECC unit?
When I press the recirculating switch to block outside air comming into the cabin I suspect the actuator doesn't close the port for outside air entering through the vents.
When I drive behind stinky diesel cars and press reciculating switch it should immediately block smell comming from outside.
I suspect the actuators gone stuck not closing the system?
How do I test if system works properly and see if the actuators work or not?
I have replaced cabin active carbon filter, I always use good stuff like MB OE or MANN filters
Filter doesn't help to neutralize strange smell comming from outside.
