W202 C180 Wiring Diagram(s)
Sprint-Man
Newcastle upon Tyne (Area)
W209 CLK 240
Can anyone supply or suggest a comprehensive Wiring Diagram(s) for me please, I have a Haynes Manual but it does not contain the circuitry I need to investigate a fault (namely Heated Rear Window not working)? Thank You:dk:
remove the cover from the rear of the fuse box (6x screws). there are two big black relays, it is the slightly smaller of the two.
The unit marked '201' which contains 3x relays on a PCB? What is the purpose if the other 2x Relays?
