Jamestrout
- Jun 7, 2013
- 1999 C200 elegance
Hi, I have had a problem with my auto box on my 1999 W202. (C200)The pipe corroded through from the gearbox to the inter cooler at the front of the car.
I repaired the pipe & fluid was still leaking from under the car so I replaced the pilot bush & replaced the fluid to the correct level.
The car now seems to be in limp mode, and only drives in 1 gear & reverse and when changing gear the car seems to to jolt violently. I gather that there could be an error in the ecu? Is that error code store within the transmission ecu? (Passenger side footwell) If I changed this would this clear the code, (as the repair has been done) the nearest MB dealership is over 60 miles away & I can buy a transmission ecu for around £20.
Any help or advice would be appreciated.
Thanks, James
Thanks, James
