Royville
Hi all,
Just reactivated my account after letting it fall dormant for many years.
I've always bought and used merc's over the years without any issues and found them to be very reliable.
My current car I've had for around 7 years without any issues - until now that is...
I have not been using my car for a while and this cold weather killed my battery, so I purchased a new one and fitted it myself. I connected the +ve terminal first then -ve. There was a slight spark but all seemed well and the car started up okay.
But then I noticed the two messages on my display.
Both the coolant & washer levels are full, so these are false readings. Has anyone seen this before? Does anyone have any suggestions as to the likely causes please?
I've seen that many faults can be put down to the SAM but aren't there two or more on these vehicles?
Any advice would be greatly appreciated if you could help.
Thanks in advance.
1. Top up coolant - See owners manual
2. Top up washer fluid
The second one appears after the first one is cleared.Both the coolant & washer levels are full, so these are false readings. Has anyone seen this before? Does anyone have any suggestions as to the likely causes please?
Thanks in advance.
