Hi all,
Having an issue and in need of help please!!!
I had an issue with my 2002 c220, and it was leaking fluid, it failed the MOT and it turned out the fuel pump was leaking badly and they installed a recon unit.
Now a week later it will never start first time, it turns over but it takes 10 mins to fire (not 10 mins of cranking but trying and then waiting and trying again)
The first time you try it fires up but then cuts out (even if you rev the engine)
When you turn to position 3 you can hear pumps running, but it just cranks and wont fire.
I am a half layman so have no idea what it is.
If it sits for say 3-5 hours it will fire first time, but more than that is less likely.
Could it be the fuel filter? it needs a service, but I know that wont have anything to do with the ignition or fuel system.
I have used Red X on it to see if it was a fuel issue and its still there.
The ignition did blow a fuse a few months back and that was replaced.
Thanks for any help
Thanks for any help
