irishjas
My front end doesnt sound right when going over bumps in the road. Also when breaking at 30+ mph i get a vibration. Its just passed its mot. Any ideas
Absolutely, but easily missed on some cars.If there was surely it would have failed the test?....drop links are a test item....
So could be an expensive job if bar needs replacing?On that age car, if original then all rubber bushes on the suspension will be well past their best or heading towards finished. It needs to go on a ramp with someone who knows what they are doing so they can check all suspension components and arms. Anti roll bar bushes also likely detached from the bar, but they are usually bonded to the bar so a replacement is usually a new bar from Merc.
The vibration when braking could be something else. Again, I'd at least pay a Merc independent specialist for an inspection and get a quote for what they think needs doing.
Mot report does say advisory on off side bush, slight playI would consider removing the drop links to see if there is play.
When I did this job DIY on the drive, you can just jack up the front a bit and put on low axle stands to take the car. It was a relatively easy job, so I'd guess a garage should be easily able to do it in an hour or two.So could be an expensive job if bar needs replacing?
So i could just replace the bushes on the roll bar + drop links ?The two rubber bushings the sway bar pass through are separate part numbers as are the 4 'dust caps' that are supposed to protect them . + 1 for doing fitting new drop links while you are at it.
Ive seen one on ebay with bushes for just under 100, and pair of drops for 17When I did this job DIY on the drive, you can just jack up the front a bit and put on low axle stands to take the car. It was a relatively easy job, so I'd guess a garage should be easily able to do it in an hour or two.
The anti roll bar something like 10 years ago was £50 direct from Merc, so at that time not very expensive.
Replace the drop links at same time as they are inexpensive and need to be disconnected.
Send your reg or VIN number to the Newcastle Mercedes Benz ebay store and ask them for a delivered price for the 3 items. That way you will have 100% the correct bits and very good quality. If you want them, they will set up a buy it now auction and send you the link.So i could just replace the bushes on the roll bar + drop links ?
Thanks for the advice, i will have another look laterSend your reg or VIN number to the Newcastle Mercedes Benz ebay store and ask them for a delivered price for the 3 items. That way you will have 100% the correct bits and very good quality. If you want them, they will set up a buy it now auction and send you the link.
It seems from Petrol Pete's different experience to mine, that depending on exact model or years, some ARBs have bonded bushes, and some have replaceable bushes. Both are possible.
You might be surprised at how competitive MB Newcastle prices are.
