nick9955
hi new to this forum but I have a problem that isn't a big issue but don't want to keep throwing money at it.
I have a cl203 2005 with the m172 engine 180 k
so I had this problem where whenever I started the car the rpms will be very high (1.5k) for a second then slowly drop to normal but it will jump around a little, then if I put it in drive or reverse the rpm will jump around like crazy between 0.5k and 1.5k will drive fine at speed no hesitation or poor mpg etc. but if I ever come to a stop in the journey the jumping comes back until I start moving again, also I had an intermittent code for the maf sensor and for too rich or too lean mixture.
since then I have replaced the maf sensor, this has fixed the problem almost completely.
on cold start it will still rev high and jump a little when selecting reverse or drive. when warm all of this is gone.
The problem is I have is a constant engine management light for maf sensor which will go away if i erase the code (it won't come back in that drive) but whenever i turn the car off and on again the code always comes back and its always for the maf only.
any idea why the light still comes on? it is running so much better than before and not throwing codes for mixture anymore either, but the constant light is so annoying.
