W203 OM646 C200CDI turbo oil leak
Hiihen
Finland
S203 C200 CDI
Hi, Workshop changed engine head gasket 4000km ago and fluid leaks have been tracked down since. One oil leak is left and I try to locate it first myself.
This leak marks oil drops under the turbo, or it is highest point I see it without disassembly (images). Front face of engine is dry and turbo side face is slightly oily.
Parts diagrams of this area would be helpful if someone have them. Also hints of possible leak points of oil lines around the turbo are highly appreciated.
Before gasket change I didn't see any noticeable leaks so what is disassembled for the fix are most likely leak sources.
