Hello everybody,
I have a problem with the parking sensors on my w203 2006. Icarsoft is showing me the connection to one of the front sensors is bad or the sensor has gone bad. After switching sensors with another front sensor it gives me the same fault code for the same sensor position, which means the sensor isn't the culprit. After reading online I found that moisture might have gotten in the connector that all the front sensors connect to and it should be located somewhere behind the front right wheelarch. Can anybody help me pinpoint where that connector is exactly located?
