johnnyboy369
Hi, new member seeking help: Recently noticed a Kickdown fault insofar as only drops 1 gear before losing power. It will then drive sluggishly until stop/start and issue clears but reoccurs again on next Kickdown. Diagnostic check revealed only Fault Code: P008A-21 The pressure in the Fuel low pressure circuit is to low. The signal amplitude is less than the minimum amplitude. Would this fault repair relate to the Kickdown problem and if so what is the repair?
