W204 Air Con Compressor
Rich H
Warwickshire
C63 Coupe
So, the air con stopped working.
Pressed the A/C button and the light flashes twice and then goes off. (2013 car so LED is lit for A/C on).
I took it to be re gassed and it was completely empty.
It held a vacuum and filled OK but when I switched it on even after a few minutes there was no cold air.
The Mechanic is telling me that it is a compressor fault because, at it is driven continuously by the belt, there is an internal clutch which fails.
As he still hasn't found out where all the original gas went, so there may be a leak somewhere, he de-gassed it.
So to get it fixed will be about £900 including parts labour and A/C gas.
Anybody else had this problem?
Yes, we've all had this problem of being ripped off! £900?? Geeze, a new compressor touches the £200 mark, a regas can be done for £60. A competent A/C guy could track down a leak at relatively little cost. That amount seem very, very high, but hey, it's your buck!
BRAND NEW AIR CON COMPRESSOR/PUMP MERCEDES C-CLASS W203/W204 / E-CLASS W211/W212 | eBay
