Indotwenty4seven
The cooling fan on my 2014 C220 is running constantly, checked the code with MB 2 scanner and it indicates air con pressure sensor is open circuit, my question is there a way of testing this sensor to check if its a sensor or wiring fault? I tried unplugging the sensor but the fan still stays on.
Should the fan stop when the sensor is disconnected?
Any help appreciated thanks in advance
