Red302
Hi all,
I've got a 2013 W204 C250 Cdi with the AMG pack. I've had it around 4 months and it is just shy of 120000 miles on the clock.
The car wasn't driven during the last week of cold weather, but now the EML has come on, and at idle, there is a slightly noticeable "shake" which I assume is a bit of a misfire. other than a slight drop in performance and change of engine tone, it seems fine. My blowers are also a bit intermittent, but less of an issue.
A friend has an OBD scanner, so we plugged it in today and got the following outputs:
P008791 - Fuel pressure too low
P047128 - Exhaust back pressure sensor 1 has a malfunction
P008922 - Fuel pressure regulating valve 1 has a malfunction, signal amplitude is greater than maximum.
The Control Unit Fuel Pump shows as OK.
These show as STORED as the EML has gone off, but the engine "sway" is still noticeable.
Does anyone have any ideas on what the fault could be?
It also showed the following faults that I assume are unrelated, but I haven't recognised any other faults, and I'm not sure what these refer to:
B179715 - Left standing light 2 has a malfunction. there is a short circuit to positive or an open circuit
B179B15 - Right standing light 2 has a malfunction. there is a short circuit to positive or an open circuit
Can anyone shed any light?
Thanks in advance!
Thanks in advance!
