Goody71
My serpentine belt failed today and i'm trying to get it off but it seems stuck behind the ac pulley.
Can the pulley be taken off or loosened?
Removing the pulley should not be necessary, can’t you grab the belt and pull it out? A jerking action is usually effective. Alternatively attack it with a Stanley knife? You’ll be fitting a new one anyway.My serpentine belt failed today and i'm trying to get it off but it seems stuck behind the ac pulley.
Looks like it was a plastic pulley. Ordered the serpentine kit that includes the belt, 4 pulleys and tensioner.I don't know , but from what I have seen whenever you see them for sale (new or used) the pulley seems to be an integral part. Or at least one that would be a real pig to get off with the pump in situ. DENSO AIR CON COMPRESSOR FOR A MERCEDES-BENZ C-CLASS ESTATE 2.2 70KW | eBay
I hope you get it sorted, pretty cramped working down there. Any idea why the belt went pop ?
I will let the technician at work sort it out now. Almost got my arm stuck yesterdayRemoving the pulley should not be necessary, can’t you grab the belt and pull it out? A jerking action is usually effective. Alternatively attack it with a Stanley knife? You’ll be fitting a new one anyway.
So how many alternator pulleys have you changed or bought for £25 ?yes is very simple if you have correct tools, just a simple spline and long torx set up, the alternator pullies are cheap about £25, and if you have it all striped out even if ok for cost of part change anyway
again I would def check all pullies before replacing AC pully
if you do an internet search the AC pulley delaminating the outer ring from rest of ft is common for damaged belt
But an RMP related issues is not as common with damaged AC pulley, usually point to alternator or other pulley
I could be wrong, but 100% check or replace overrun at same time for cost of £25
Tezz
Lol this is what I love about internet, trollsSo how many alternator pulleys have you changed or bought for £25 ?
