Had the car out this morning for a run - absolutely fine. Went to go into town in the afternoon and noticed it sounded weird, vibrating on idle and shaking badly above about 2krpm.
Turned around and came straight home, checked for fault codes and found:
Some Googling suggests possible O2 sensor fault, primary catalytic converter failure or failing camshaft adjuster or sensor. Where should I be looking first? Which bank has cylinders 5 through 8?
- P0300: Random/Multiple Cylinder Misfire Detected
- P0305: Cylinder 5 Misfire Detected
- P0306: Cylinder 6 Misfire Detected
- P0307: Cylinder 7 Misfire Detected
- P0308: Cylinder 8 Misfire Detected
