Hallett
Hi everyone, I’m having an issue at the moment with the coolant temperature getting very hot and ultimately finishing with coolant out of the expansion tank cap. Weirdly it seems to hold 95 degrees (which I’m sure is hotter than previously) when in comfort but when you change the gearbox to manual it seems to then overheat very quickly, no codes when plugged into the computer and have changed the thermostat so far with no difference! Hoping someone else has had or heard of a similar issues before, thanks
Dan
Dan
