Broosta
I've had issues with the ESL for a while (didn't know about the ESL issue then though) - car sometimes won't recognise the key in the ignition, with only some dash lights on and no starting. This has been a thing for a few years but recently been worse.
I thought it was battery related but after changing the battery and testing voltages and things which were good the problem did not go away.
The problem so far has only meant the car won't start for a few mins and then it will, but now that is happening more often.
After a bit more googling I'm 99% sure it's the ESL, and my car is not stuck locked or anything.
Several options:-
1) go to main dealer who can fix for about £1kish.
2) go to indy who can do it a bit cheaper.
3) or I fix it by,
i) replacing the tiny little motor which cost about £15 (might still go wrong again),
ii) replacing with an emulator for a few £hundred? (not sure how to do this - needs coding to key or something?).
Of the above options 2, 3i), and 3ii), which have people found the best?
Or are there other options people have tried?
Several options:-
3) or I fix it by,
