W205 Audio 20 Head Unit replacement
ReggieCyde
UK
C-Class W205
Hi all,
My OEM HU failed and I've purchased a used replacement. It's identical to the original, even the month of production.
I have the anti-theft code but I'm curious if it needs to be coded to the car via Star/Xentry or because it's an identical replacement from the same model (2017 C-Class) it would work without coding.
Any advice is much appreciated.
I should add that it's the bogo NTG5 HU Entry unit with sat nav (memory card type) and CD.
yes, it will need to go through a process called Initial Startup on Xentry, which will unlock it, update the firmware and send the lock code / etc to Mercedes so it is centrally stored. You will need a new memory card as old one is locked to VIN and H/U serial number
But talk to comandonline.co.uk as your old unit may be repairable and that will be easier and save you a map card too.
R
