design guru
- Feb 28, 2004
- Location
- Hampshire
- 2001 W220 Mercedes S320cdi & 2001 W208 CLK230K (SORN since 2008)
I have a C250d 2016 W205 and the windows get steamed up quite a lot. I know its cold this time of the year but this a not just condensation, I get a full build up of mist like they have been sprayed with a water sprayer. It happens mostly on the rear window but often its on the front windscreen and sometimes even the glass sunroof, and this is even when the interior lining is closed.
I have checked the seals and there are no obvious tears or loose fittings, the sunroof drain holes are clear and when the roof is opened there is no water or mist wound the fitting. Its definitely not from the roof and all the carpets are dry including the boot lining.
I use the air con and its working fine. I would expect a small amount of condensation especially when the windows are extra cold this time of the year but the build up of mist is too much.
Any help would be appreciated.
