Hi Guys
I am getting the following warning messages in my C350e W205.
'Left Daytime Driving Lamp' and 'Front Left Parking Lamp' warning messages on the dashboard. I think they LED lighting strip functions as both?
When I use the ICarSoft diagnostics I get the following 3 'current' messages:
Do these error codes point to the main lighting module failing, or could there literally be a short somewhere.
Or could it just be a fuse?
As a note: I have just had the air suspension valve block replaced which sits very close to the left hand headlight unit, so maybe something wasn't put back right?
My suspicion is that it is a failed left hand lighting module,
Any thoughts, insights or experiences would be much appreciated.
Many thanks.
Pete
- The output for the daytime running light has a malfunction. There is a short circuit to ground.
- The output for the standing light has a malfunction. There is a short to ground.
- Communication with the control module 'Multifunction Camera' has a malfunction.
Many thanks.
Pete
