Sunroof currently stuck closed and will not open electrically. When trying to open maually via the motor using an allen key only passenger side lifts partially and drivers side remains down. I am guessing there is an issue with drivers side like the rail has failed and there is now an obstruction however how do i get the glass off to investigate if i cannot lift that side to enable access to remove it. All the info i have says you need access to front of rails to remove bolts to slide back roof. Help please!!
