ZT777
I'm reaching out to see if anyone has experienced a similar issue with their W205 Mercedes and could offer some advice. I've encountered a problem with the wiper linkage on the driver side of my vehicle. Specifically, the linkage keeps popping out, causing the driver side wiper to stop working, while the passenger side wiper continues to function perfectly.
I've attached a picture to this post to show exactly where the linkage is popping out. The motor itself seems to be in good working order, as everything operates smoothly when I manually pop the linkage back in place. However, the issue is becoming more frequent, and I'm concerned about it happening during a critical moment while driving.
Before I consider replacing the entire linkage, I'm hoping to explore potential repair options to save on costs. Has anyone successfully repaired this issue, or is a complete replacement the only reliable solution? Any tips, tricks, or recommendations would be greatly appreciated.
Thank you in advance for your help!
