W208 CLK locked in "Park"
tacho d
Norfolk UK
Mercedes Benz W209 CLK 220 CDI
This has become increasingly difficult to move the gear selector lever away from the "P" position while pressing the brake pedal. There is a manual release through a flap on the selector panel which I have used and this sort of works but with also with increasing difficulty. I've been told this is a common problem caused by a switch at the brake pedal. Would that be the brake light switch or something else? Is it easily available, and simple to fit? Any ideas welcome.
Brake light switch is a common culprit for this fault. Cheap and easy to replace
