Hi all,
Had my 2006 CLK350 for a few weeks now, and have covered just under 1,000 miles with no issues until this morning.
When I was driving I noticed that the car wasn't changing up from either 3rd or 4th gear. I switched from 'comfort' to 'manual' mode but was unable to manually change gear (there was a 'D' on the display instead of the usual gear number). I came to a stop at some traffic lights and after that the car would not pull away. It was revving quite high (about 3k rpm) but would not exceed about 5mph. I pulled to the side of the road and tried to put it in park but the gear stick wouldn't move, it was stuck in the drive position. I could turn the engine off, but not the ignition and I couldn't remove the key either. After about 5 minutes I started the car and everything seemed to work fine again.
The car is booked in at my local indie tomorrow anyway as I'm getting another key for it, and I'll get them to check the fault codes but just wondering if anyone has a rough idea of what the problem is. Eg whether it's a minor component or if the gearbox is going to grenade itself.
